주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kia Optima는 2000년부터 기아자동차에서 생산한 중형 승용차로, 전 세계에서 다양한 이름으로 판매되었습니다. 1세대 모델(2001-2005)은 대체로 Optima라는 이름으로 판매되었으나, 2002년부터 유럽과 캐나다에서 판매가 시작될 때는 Kia Magentis라는 이름이 사용되었습니다.
My speedometer and odometer quit working?
As I was driving my speedometer and odometer both quit working is this something computerized or a cable that needs to be replaced?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
I have a 2005 Gulf Stream class A motor home on a Ford V-10 chassis. I went to take the motorhome out and the speedometer doesn't work but the odometer and trip meter do. Can anyone tell me what the problem may be and where the part is located to fix this problem. I did try and replace speed sensor in the rear end but didn't fix the issue I'm sure its something easy to fix but hoping someone else has had this issue
댓글 달기
답변 3개
선택된 해법
I do believe that this is computerized. All instruments are controlled by a computer/ If you have lost the speedometer, more than likely you have a bad speed sensor located in the top of the transmission. You can change yourself by unscrewing it from the transmission trans. It will have 3 wires going to it and 1 wire is brown, 1 is black/white. The only other thing would be a defective instrument cluster. There is also a way to reprogram your cluster, but that again will involve special tools. The best way of getting this evaluated is by having a garage check this with their sensors. Also, you could try a shop like Autozone who offer free engine analyzes. Good Luck to you.
이미지
이 답변이 도움이 되었나요?
점수 4
댓글 달기
try to check battery voltage if alternator overcharges ( max 15.5 volt ) this may be a reason.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It is probably going to be your reverse lights switch that was my problem they run off the same fuse my switch was stuck causing the lights to stay on and blow the fuse
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
rufus422000 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 11,301
