Charging Issue since 4 months
Charging with low power only, heat up. Not charging while shut down.
좋은 질문입니까?
좋은 질문입니까?
You likely need a new battery set the main battery is easy to replace following this guide iBook G4 12" 800 MHz-1.2 GHz 배터리 교체 You also need to replace the PRAM battery which is located under the top shield just behind the ports. Follow this guide to gain access iBook G4 12" 800 MHz-1.2 GHz 상단 실드 교체. The battery guide has the info for the button battery.
안내서
난이도:
매우 쉬움
안내서
난이도:
어려움
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 6
지난 30일: 15
전체 시간: 286
