주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1998년형 모델은 오리지널 Beetle을 기반으로 제작되었지만, 이전 모델과 비교했을 때 훨씬 더 넓은 실내 공간을 갖추고 있으며 더 발전된 기능들이 탑재되어 있습니다.
I have a p1580 code
What does the P1580 code mean ? my litle car has been fine and all of a sudden it doesn’t want to keep running, it is running rough,and I am confused as to why it has this code
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
revaschorus a P1580 pops up with “throttle actuator B1 malfunction”. Could be caused by a dirty throttle body, out of calibration or a low battery. Try this:
Disconnect your battery for 20 minutes and if you have an external battery charger go ahead and charge your battery so you have a strong battery to fire the car on initially.
Now re-connect your battery and turn the key half way where your AC and radio come on (turn your AC off)
Let the car sit for 3-5 minutes. If you put your ear under the hood on the Throttle Body you can hear the TB recalculating, it sounds like an electrical whizzing.
Now crank the car and take it for a spin it should be back to normal except the DTC P01580 still shows. This should reset after 50-75 miles of driving. from here
If that does not work, you will have to clean the Throttle Body as well as the MAF. We can most likely help you with descriptions for that as well.
BTW let us know the exact year and model of your Beetle
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
This is for a 1998 volkswagon beetle 2.0 L
의 공유
댓글 달기
The beetles and all the way back have a throttle body assembly(ies) that's('re) sealed and you just have a bad tps(throttle position sensor) usually. That is usually. The cause would be a short and vacuum or could be a bad lead, bad solder, or bad connector plate.
Unfortunately it's the entire throttle body you're seeking as far as a new part.
FOR 90s Jetta golf Passat beetle corrado, and I believe to current with them all. There is no direct SENSOR ONLY replacement for these vehicles. SENSOR ALONE REQUIRES SOLDERING AND DISASSEMBLY TOOLS, YOU REMOVE THE SMALL SENSOR, DO NOT OPEN THE GEARS UNLESS THE OTHERS, AND CLIP THE WHITE WIRE, SPLICE AND REATTACH AS WAS WITH THE NEW SENSOR.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
revaschorus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 48
전체 시간: 3,974
