주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 M4753 / 233, 250, 266, 292 또는 300 MHz G3 프로세서
Problems with startup and speakers
I have a Powerbook G3 Wallstreet 233mhz with varying startup problems. Once I plug in the AC adapter, the fans spin very loud and the green light illuminates for a couple seconds. After that the computer becomes silent. When I press the power button, both speakers emit a buzzing/chirping sound and the system starts up. The buzzing/chirping sound continues as long as the computer is on. Sometimes the computer will get to the screen that says "Mac OS 9.2" and then display an error message with a bomb and it will say "A system error occured. Please restart your computer." I have already tried reseating the processor card and examining the hard drive. Any help is appreciated.
Update
I can't believe it! I let the Powerbook G3 sit overnight without the battery or AC adapter plugged in and it works wonderfully again! Thanks everyone.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Coconut battery has an older version that will work with 10.2. You might give it a try to check the condition of your battery. The only way I know to get it is to download the new version and try to run it. It will then give you a link to the older version: http://www.coconut-flavour.com/coconutba...
의 공유
댓글 달기
답변 1개
선택된 해법
Try starting up from your system installation disk by inserting the disk and restarting holding down the "C" key. If it starts go to utilities and see if you can repair the hard drive. Let us know what works, thanks.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I will do that as soon as possible and post it tomorrow.
의 공유
댓글 달기
답변을 추가하세요
Jack Byrnes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 1,183
