์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
Sony Cyber-shot DSC-W830์€ 2,010๋งŒ ํ™”์†Œ ์นด๋ฉ”๋ผ๋กœ, ์ •์ง€ ์˜์ƒ ์ดฌ์˜๊ณผ ์ตœ๋Œ€ 720p ํ•ด์ƒ๋„์˜ ๋™์˜์ƒ ๋…นํ™”๋ฅผ ์ง€์›ํ•ฉ๋‹ˆ๋‹ค.
SD card write protected
my SD card is write protected so I canโ€™t take pictures. It happens with every SD card I use. The physical write protection is turned off, I canโ€™t reformat the card because I just get a pop up that says the SD card is write-protected.
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
Hi,
Can you format the SD Card in a computer and then try it in the camera?
If it still fails, it appears as though the contact in the SD Card reader in the camera, that detects the position of the lock switch on the SD Card may be bent or stuck, indicating the card is locked when it isn't.
Youโ€™ll probably have to open the camera to access the SD card reader and most probably have to replace it.
Hereโ€™s a link to the ifixit Sony Cybershot DSC-W830 ๋งˆ๋”๋ณด๋“œ ๊ต์ฒด guide which may be of some help in gaining access to the card reader.
If this seems too daunting, contact a reputable, professional camera repair service and ask for a quote
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 2
๋Œ“๊ธ€ 1๊ฐœ:
I put the card in the computer, but it still failed in the camera. So I will follow up on this solution. Thanks!
์˜ ๊ณต์œ
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
tagarrison ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 5
์ง€๋‚œ 30์ผ: 16
์ „์ฒด ์‹œ๊ฐ„: 767
