주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony TCM-919는 오디오 녹음 기능을 갖춘 휴대용 경량 카세트 플레이어입니다. 1990년대의 이 기기는 3자리 테이프 카운터, 마이크, 자동 정지 기능, 전면 스피커 시스템을 탑재하고 있습니다.
Cassette player does not turn
The unit is actually a tcm 450 but the particular model was not present on the selection list. I found it in my grandma’s drawer along with a bunch of tapes, and I’m pretty sure it worked a year ago or so. when I shoved a tape in with aaa batteries, nothing happened. I removed the tape to see if the knob thing inside was turning, and it didn’t. Ibplayed with the volume knob and all the buttons, but it was failing to work. I can feel that the cassette player is trying to make it rotate— I can feel it when I touch it with my finger while pressing the ‘play’ button, but yet, nothing is happening. Plz Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Hi @pxlbluejay ,
Here’s a link to the service manual for the cassette player.
It has full schematics of the player which should help you find out where the problem lies. If a component is faulty it also has the parts list.
Hopefully this is a start to get the player going again
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
jayeff,
thanks a lot!
의
댓글 달기
Probably a bad drive belt. If you can open it up and take a look chances are that the old rubber belt has gone soft and stretchy, without the right tension the motor wont be able to drive the pulleys. You might hear a mild screeching noise when you hit play, most likely the belt skipping. You can buy replacement belts on ebay or maybe amazon.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jay Kwon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 29
전체 시간: 1,482
