주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
When calibrating the battery, would it be bad to use the fast charger?
So, I am going to be doing a battery replacement on my uncle’s old Galaxy Note 5. While reading the guides here on Ifixit i saw the link to the battery calibration page, where I read all about it. (If you don’t know what that is, go read about Battery Calibration ) I have since been wondering if I should or shouldn’t use the fast charging brick when i charge it up to 100%. Any advice wold be appreciated! Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hey. I’ve heard so many conflicting opinions on the matter. Everyone says different things and there is no definite answer anywhere really. But using the fast charger does cause the internal circuitry of the battery to dissipate more heat,so it puts more thermal stress on the battery. Based on my research,using a slower charger is better than a fast charger in the long run. It isn’t as stressing to the battery as fast charging. But keep in mind the battery and charger are designed for each other. The phone is designed to accept higher current. So it is safe and will work well.
With my iPhone 6s Plus I charge with a 2 amp charger instead of 1 since by the time the battery goes bad I’ll probably get a new phone.
For calibrating,it technically would be best to use a slower charger,but in practice it really isn’t worth worrying about.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks. That does make sense, but I will continue to use the fast charger because I can always replace the battery again! Or I could take the realistic view on things and say the phone will probably be dead by then ;) Thanks for your help!
댓글 달기
귀하의 답변을 추가하세요
Linktoad64 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 12
전체 시간: 409
