주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 10월에 출시된 Microsoft의 2-in-1 노트북용 키보드입니다. 6세대 Intel Core i5 또는 i7 프로세서가 탑재되었습니다.
Keyboard battery not charging
Out of the blue, battery 2 (the battery located in the keyboard) stopped charging and is now permanently at 0%. When the Surface book and the keyboard are connected bettery 1 (the battery located in the screen is charging normally).
I tried replacing the battery in the keyboard, but it didn't help. What do you think could be the solution? I tried to find a replacement GPU board without success.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개:
Hi Luca, I have the same issue. Did you manage to find a solution?
Thanks!
Constantine
의
Nope. It needs a replacement of the logic board inside the keyboard. Couldn't find a replacement logic board and a new keyboard is expensive considering that it's an old machine. You find from now and then second hand keyboards around, but didn't bother to look for it actively.
의
댓글 달기
답변 3개
Hey. I’m not sure what you mean by gpu,but as long as the surface tablet works fine,you can probably get a new keyboard. It’s really down to the possibility of a power management issue in the keyboard. This can be a loose connection somewhere,a damaged component,etc. You may want to look into buying another keyboard for it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
As an electrical engineer i am trying to hunt down a similar problem. i have an undesirable voltage on my battery cells and my laptop charger is not propagating through the board. so i am trying to go through the chips to make sure things are turning on but some how 15V is creating a 3.3V rail. but my input protection mosfets are not turning on to allow the 15V to go to the battery charger.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ok I have the same issue that the keyboard stopped working, so (don't laugh) I pulled the keyboard of the surface, spit on the terminals and rubbed very hard to kind of clean them, and walla my keyboard now works.... :-) Hope this works for others its worth a go...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Luca Vicini 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 43
전체 시간: 5,635
