주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 8월에 발표된 Galaxy Note8은 리콜된 Galaxy Note7의 후속 모델입니다. Note8은 2017년 9월 대중에게 공개되어 판매되었습니다.
Device will not power on
My Device will not power on.
Powerbutton stopped working, I did not care, but when the screen fractured I send it for repair, the workshop manage to change screen and start the phone witout powerbutton. but then it went out of battery. I charged it fully. It did not boot automatically.
I wnt to several workshops they did not manage to start my device. There ar to capacitors located on motherboard near powerbutton. these capacitors / resistors have decomposed due to water damage.
When I charge, display shows battery status.
when I try to boot in to download mode it wil not engage download mode.
  1. is it possible to replace these components without replacing motherboard ?
  2. Where can I by these components ?
  3. Is there any other way to boot samsung galaxy note 8 without power button ?
# Is there any way to extract data from device ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Do you have any skill when it comes to soldering? its not easy to solder on new connectors but its possible.
Also have you tried just getting the corrosion removed with some cleaning alcohol ? You might be able to clean them up enough so that the button will start to work again.
Try to plug the phone to a power source and hold the volume down button. In the boot menu you can choose to restart it which should turn it back on.
hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Iftikhar Mahmood 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 31
전체 시간: 236
