주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony에서 출시한 11.6인치 터치 스크린 태블릿이자 Full HD 노트북입니다. 2012년에 출시되었습니다.
sata cable connection between two computer
how can i connect two computer to send data using sata cable?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
It is not possible to use SATA to connect two computers together, mainly because it is a host/device topology. This means the host sends a special "host-to-device" command, and the device sends different "device-to-host" commands back.
It would be possible to connect two computers using SATA with your special SATA translator device in the middle just like USB cables .You can't connect two computers together with a bare USB cable, because they are both hosts with no devices to talk to.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There is no such thing as a SATA to SATA translator device between two computers. You will need to either a means to connect your systems together with either an network connection (Ethernet or WiFi) in a peer connection. Or you’ll need to remove the SATA device and fit it within an external case to then connect to your other system. Or use an external USB drive to copy off your stuff and then copy to your other system. If you have a cloud based backup you could also leverage it as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
asmie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 428
