주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pavilion Notebook 17 시리즈의 17인치 노트북을 위한 수리 안내서 및 지원 문서입니다. 해당 노트북의 모델 번호는 17-g000 ~ 17-g099입니다.
System Fan (90B) error
Hi
The laptop gives this error at the BIOS boot up stage.
The fan sounds like it spins up and down a few times.
The system then shuts down.
I opened up the laptop and the fan spun freely with my fingers. I put it back together, updated to the latest BIOS and it was ok for a few days.
It’s now doing the same again.
Any ideas please ?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
가장 유용한 답변
Fan needs to be replaced, had one that would intermittently display that error and replacing the fan fixed it. This is on a HP TPN-C125 general model.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi @netdudeuk
I’ve fixed with this issue a lot in the past with HP. The bios on many older models can get stuck and will need a CMOS battery reset. You can simply remove the button battery and re-install, but I would recommend replacing it. It would be a good idea to complete a BIOS update as well if one it available.
If this issue continues even after the battery is reset, it may be a sign of BIOS failure.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Have you tried blowing the dust out of the fan? Too much dust can make a fan under-perform , which will cause a 90B error.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
이미지
Hi
I removed the heat sink and fan and there wasn’t a speck of dust. I applied thermal compound and re-fitted it.
I replaced the backup battery.
The laptop started up ok many times.
The error had returned this morning though.
I turned the laptop onto it’s side and blew into the vent. It then started up ok again !
I wonder if there are certain positions where the fan cannot start ?
There are plenty of replacement fans for HP laptops on eBay UK but it isn’t clear if they would be compatible.
For example, this looks similar.
https://www.ebay.co.uk/itm/HP-17-X-Fan-1...
I have attached a picture of mine.
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
BTW, thanks for the previous replies.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Steve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 23
전체 시간: 3,957
