주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer One 10 S1003-114M은 태블릿과 노트북으로 모두 사용할 수 있는 컨버터블 기기입니다.
Power on and off immediately
I installed windows 10 after installation, when powered on, it just blink light and off, it starts getting hot immediately. What should I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
It’s a security measurement, when the CPU overheats the PC immediately shut down to prevent further damage, so you need to :
  • Check your fan if it spins or not
  • Clean the radiator (remove dust)
  • Make sure there is nothing on the airflow path (intake & exhaust)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have removed all cables and reinstalled all but it can't start without switching on button it is starting automatically and turning off in a second
의
댓글 달기
I don't think it has anything to do with the W10 install. Sounds like the CPU might have shorted out. It happened to me once.
It might be possible to remove the CPU and power on to verify it stays on with the CPU removed. However, that could be a tricky process.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jerry Arickmun Dandi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 15
전체 시간: 406
