ignition problems need help
My starter stays on after car starts
좋은 질문입니까?
James Clark could be bad wiring to the starter, stuck starter solenoid, a bad ignition lock cylinder that keeps the actually ignition switch in the START position as well as a few other things. I’d start with jiggling the ignition lock a couple times in different directions etc. to see if that fixes it (unless you can get to the harness and “hotwire” it that way you bypass the lock totally;-) If that did not change anything, replace the starter/solenoid and see if that fixes it. Here is a schematic that should be identical to your system (depending on exact model/year).
Let us know what you find.
이 답변이 도움이 되었나요?
James Clark It seems that the starter solenoid contacts are sticking and not releasing the solenoid, as mentioned the return spring could be broken also.
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 640
댓글 1개
Sounds like the Bendix spring is sticking.
Take it to a qualified mechanic for repair.
Michael Shaw 의 공유
