주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
8.9인치 또는 10.2인치 LED 백라이트 디스플레이, 1.6GHz Intel Atom N270, 2008년 10월 29일 출시.
pc not turning on
after heating it shut down automatic and now its not turning on
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
naz, the possibilities are to numerous at this time to give you a definite answer. Start systematically to narrow it down. Make sure that your power supply is working. Take a multimeter and make sure that the output voltage is correct. I believe it to be 19volts for your mini. If you have power from your AC adapter, remove the adapter from the computer, remove the battery and remove the memory module. Leave it out for a while. Then replace the memory and the AC adapter and see if it starts. Also replace the battery after. If it still does not show any sign of life it is time to take it apart and visually inspect for any burned capacitors, you will recognize those by a bulging top. Also make sure that you clean the fan and the air vents and make sure that your computer has good airflow. The service manual is available right here http://h10032.www1.hp.com/ctg/Manual/c01...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
عاوزه كل حاجه تخص عطل أنه الجهاز مش بيفتح نهائي
의 공유
댓글 달기
I am trying your sugestion.
I did remove the memory to add a 2GB memory,, the mini had been off 2 days when I did this, and the the battery was in and the charger wis disconnected, but plugged in
I will let you know
youtube had no help at all koddos to you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Please make sure your power supply is working properly. if is properly connected but still you are having the same problem, you need to check your motherboard and processor fan. it might be problem from there.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
naz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 27
전체 시간: 3,999
