Is non removable battery good?
I would like to know if there is any way(trick) to check the battery if its still alright by not buying expensive stuff to test it with.
좋은 질문입니까?
좋은 질문입니까?
Hi,
You could always try using software - example only to give you an overview of the battery’s condition
이 답변이 도움이 되었나요?
Oh sorry considering my laptop won't turn on is based for my question.(troupleshooting), thanks.
Hi,
It doesn't turn on with the charger connected then?
Does the charge indicator light on the laptop come on when the charger is connected?
Does the power jack feel "loose"? Plug in the charger to the laptop (do NOT switch the charger on) and gently try to "move" the plug from side/ up and down to side to check for any movement indicating that the jack may be loose from the motherboard
Has the laptop been dropped or gotten wet at all?
Have you tried a different compatible known working charger to see if the laptop starts up?
What have you tried?
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 423
