2003 Durango will not crank
my 2003 will not turnover, replaced starter and computer and still will not even crank over. any ideas???
좋은 질문입니까?
좋은 질문입니까?
@redneckchef since you replaced the starter motor we are going with the assumption that it is not the issue. Start by checking these things
Here is the part of the SM that deals with the starter etc. Durango-Starter.pdf and the starting system wiring Starting-System-Wiring.pdf
Let us know what you find out.
이 답변이 도움이 되었나요?
check all your fuse and swap the starter relay with a relay of the matching number in the PDC (black box under the hood) it sounds to me like your not getting power to the starter
이 답변이 도움이 되었나요?
Look for rubbed wire harness going out from the computer and be sure there are no broken wires.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 4
지난 30일: 27
전체 시간: 967
