주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 11월 출시, 모델 번호 RCT6077W2, 4GB 저장 공간, 7형 터치스크린.
Turns On, Wont Work?
Recently I had rediscovered this tablet and decided to use it for work purposes. Not even a day later a friend of mine thought it would be funny to smack the think out of my hand and onto the hard pavement. Miraculously, The only physical damage that could be seen is a slight crack through the left part of the screen itself. However when the actual device itself is turned on the entire left side is simply unresponsive while the right works perfectly fine. I’v already tried most of the normal tips and tricks (turning it off and on, factory reset, etc,) but nothing seems to actually be working. What would be the best course of action?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
I’m assuming that the LCD screen is OK, i.e. full display on entire screen and that the touchscreen (aka digitizer) is not responding on the left side. Is this correct?
If so then the touchscreen either has a loose connection to the systemboard due to the fall or it is faulty (you mentioned a small crack) and needs to be replaced as it cannot be repaired.
Here’s a link to the ifixit RCA RCT6077W2 guides, which may be of some help in gaining access to the digitizer’s motherboard connection so that you can check if it is OK or not and also the screen if you need to replace it.
Here’s a link to just one supplier for the replacement part.
It is shown only to give you an idea of the cost of the part and what it looks like. There are other suppliers online that may suit you better. Just search for RCA RCT6077W2 touchscreen to get results.
I suggest that you also bill your friend for the cost of the repair (and your time). After all this is their fault.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks again, I do appreciate it
댓글 달기
답변을 추가하세요
Someone Noone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 12
전체 시간: 292
