주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JXD S7800B는 Android 운영 체제로 작동하며 제어 장치가 내장된 태블릿/게임기입니다.
Replacement Joystick Hats Needed
Where can I get replacement joystick hats for the JXD S7800b in the UK or evenb US if they ship to the UK? I tried to order from the official site but after a month they never arrived and now they’re ignoring my emails.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I seriously doubt that the JXD official was out of service back in 2017.
It appears that the joystick hat can be unsoldered from the PCB and a replacement soldered back on.
So I think the best way is to get a cheap used one and replace the hat from that one to the current one if it runs well. As there are really cheap bargains out there.
https://www.keeboshop.com
https://www.ebay.co.uk
To save you more money, I think you can also find substitutions/alternatives that can fit your device.
Hope my answer helps you.
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
If they were out of service 2 years ago then they are back up. Their site is still up and taking orders. And I need the hats not the joysticks. There is nothing to solder.
http://www.jxdofficial.com/jxd-s7800-spa...
의
@mforcevirus Yes, I mean that you can just take the hat from a cheap one, as there's hardly supplier for the separate part. Othrewise, waiting for jxdofficial reply would be the only way. Thank you!
의
Ah I see. When you mentioned soldering off from the PCB I thought you meant the actual joystick and not the plactic hat that just pulls off. As for JXD, They were quick enough to ask me to prove that I had order details but in the past few weeks they have been ignoring me so I opened a paypal dispute.
의
@mforcevirus Or maybe you can also try to find a substitution of the JXD joystick hat.
의
I did try searching on ebay but most of what I found was for the Playstion controllers. None of the ones I've search for give much detail about the size and on the S7800b they sit on a very thin pin.
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
mforcevirus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 613
