주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota 베스트셀러 소형차의 6세대(E90) 모델입니다. E90 Sprinter, Holden Nova, Geo Prizm으로도 판매되었습니다. 이 세대는 서브콤팩트(subcompact) 차량으로 분류된 마지막 Corolla이며, 완전히 전륜 구동 또는 사륜 구동으로만 출시된 첫 번째 Corolla입니다(이 세대부터 후륜 구동 옵션이 제외되었습니다).
this is my problem
first problem of my corolla Toyota is grounded, the battery is becoming weak when engine stop. i used to recharge my battery everyday. when i start, it will start, but when i did not start the engine within three days, the battery would weak and cannot afford to start the engine. until now ,its about one month that the engine did not start. please advise me on how to repair
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
i dont know on how to answer my question.
의
Hi,
If you can charge your battery enough to start the car, once the car has started use a Voltmeter to measure the voltage across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC.
If it measures less than 13.8V DC then there is a problem either with the car's alternator or voltage regulator and the battery is not charging when the motor is running.
If it measures more than 14.5V DC it is overcharging the battery which could damage the battery.
Be safety aware when you do this as the engine is running!
Also ensure that the emergency brake (hand brake) is firmly applied
의
My Engine not start.please help me
의
Fuel tank is full of soil and rocks
의
댓글 달기
답변 1개
We need the exact year of your car, also the battery may be shorted internally or have a dead cell so you should charge it up fully, to save time, then take it to your local auto parts store for a free test. If it is good then we can help you find the parasitic drain in your car. This test will involve an amp draw test which will use a multimeter, do you have a multimeter that can test amps? If you have one, do you know how to use it properly to test amps? Here is some help.
https://www.youtube.com/watch?v=KF1gijj0...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Teodoro Achas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 23
전체 시간: 928
