주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson DC44 Animal은 반려동물의 털을 제거하는 데 특화된 Dyson의 무선 진공청소기입니다. 모델 번호: DC44 Digital Slim MK2.
brush Head not turning
The brush head on my dyson is not spinning. No blockage or tangles. Think it’s the motor. Is this repairable?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Hi,
With the brush head removed from the vacuum cleaner, do you get sufficient suction at the end of the rod that it attaches to?
Is the battery fully charged?
Is the filter clean?
의
Does anyone know where to get a replacement motor?
의
For parts from my experience eBay is 9/10 the best place
의
댓글 달기
답변 1개
If the suction is ok, its probably due to hair being caught under the motorised head rotator.
  1. Take out the brush
  2. With a hexagonal screw driver head, not sure what size to be honest, remove the screw from the center of the rotator.
  3. Lever out the rotator.
# Use a pair of tweezers to remove any hair, you’ll be surprised as to how much there is.
  1. You may have to add a little grease
  2. Replace rotator, tighten up screw. Ensure it can turn manually.
  3. Test by attaching to battery and pulling trigger.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have this problem but the brush is clear. It appears the power for the little electric motor is not being sent by the main unit down the two pins. How do I get inside to see why power isn’t getting through?
의
댓글 달기
답변을 추가하세요
Joanne McGrath 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 16
전체 시간: 2,985
