주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Salter 모델 1036은 최대 용량 5kg 또는 11lb의 디지털 원형 주방용 저울입니다.
Opening the battery compartment
The screw holding the battery compartment shut is so tiny and so tight I cannot open it, despite trying very small screwdriver and smallest allen key. They are all too big!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
There is no screw holding the cover
there is on my scales too. Looks like it has been put on as an afterthought because it came open too easily
댓글 달기
답변 2개
가장 유용한 답변
@deirdremoylan without actually seeing it or knowing the size of it I would recommend a really good tool kit something like this Mako Driver Kit - 64 Precision Bits or even this one Manta Driver Kit - 112 Bit Driver Kit With those kits you will always have the right tool for any repair.
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. 이미지
제품
$39.95
Our most comprehensive bit kit for the ultimate repair enthusiast. 112 bits designed to fix every household tech device. 이미지
제품
$69.95
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Dear Oldturkey03, Thank you so much for taking the time to reply to my enquiry. I actually have a kit with 75 precision bits (different make, I live in Ireland) and there is nothing small enough in it. However I notice that your bigger kit has possibly some even smaller sizes - 0001 crosscrew. I will try and get one in a hardware store (I don't want to spend 3 times as much on another bit kit as I spent on the scales for the sake of one little bit!) But I really appreciate your help. Thanks. Deirdre
@deirdremoylan agree with what you are saying. If nothing else and ,depends on your town/city, a good jeweler will always have the right tools to help you out.
Brilliant idea! (My watch has a similar sized screw, now I think about it, and has to be dealt with when I get a new battery.) Thanks a lot!
댓글 달기
I have a small screw driver to fit this screw, still does need t open it. Looks like new scales, but not Salter. Rubbish!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
FinntheCool 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 57
전체 시간: 9,375
