주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Yoga 2 13"는 측면 힌지를 사용하여 노트북에서 태블릿, 텐트 또는 스탠드 모드로 전환할 수 있습니다. 2014년 1월에 출시되었습니다.
USB ports are not working
They stopped working after I connected some bracelet charger and power pins got in contact (short circuit), Laptop gone off and when I power it back none USB works, I tried everything, all software things and removing battery and putting it back.
I guess some USB chip is dead?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @nemanjam291,
More likely you blew the power supply circuit that is supplying the USB ports.
Try connecting a USB mouse or any USB device that shows that power is being supplied e.g. red laser light on USB mouse or mobile phone indicating it is being charged.
If there is no indications then the power is not there.
Open the laptop and check if you can find the motherboard board number.
Once you know that, search online for a schematic for the motherboard using the board number only e.g. search for (insert board number) schematic or perhaps (insert board number) wiring diagram.
If you’re lucky and one is available online it will be of great help in locating and repairing the problem.
Here’s a link to the laptop’s hardware and maintenance manual that may help with gaining access to the motherboard.
If this seems too daunting, contact an authorized Lenovo laptop repair service and ask for a quote to repair the laptop, as they may have access to the schematics etc if they aren’t publicly available.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Nemanja 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 1,401
