주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2년의 공백기를 거친 후, 2005년형 Sportage가 다시 출시되었으며 2005년형 Hyundai Tucson과 동일한 Elantra 기반 플랫폼을 공유했습니다.
Rear door handle replacement
Do I need to remove the cover for door to replace the broken door handle ?
thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
تعمیر چراغ سقف
의
@mohammadsh70721 what year is your Kia Sportage? What happened to the light? You have already checked the bulb? what else have you already checked?
Translate
@mohammadsh70721 کیا اسپورتیج شما مدل چه سالی است؟ چه اتفاقی برای چراغ افتاده است؟ آیا لامپ را بررسی کرده‌اید؟ چه موارد دیگری را چک کرده‌اید؟
의
댓글 달기
답변 1개
선택된 해법
Hi @sam77 ,
Yes you have to remove the door trim, the glass, the rear channel and the outside handle base to get to the outside door handle.
You don’t give the exact year model or the engine type but I’m assuming that the rear door handle removal procedure is the same for all 2005-2008 Kia Sportage, all engine types.
Here’s a link to the 2005-08 Kia Sportage repair manual Body (Interior and Exterior) section.
Click on the download pdf icon at the bottom of the document box (next to the zoom 100%) to download the file to make it easier to use.
Once you have the file open it and then scroll to p.72/139 in your .pdf viewer to find the procedures to remove/replace the outside door handle.
The door trim removal procedure starts on p.67/139 and the rest just follow on after that
It is simpler if you look at the manual with the pictures than if I describe how to do it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Hussam Askar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 40
전체 시간: 4,082
