주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VG248QE는 2013년 1월 Asus에서 출시한 24인치 게이밍 모니터입니다. 144 Hz 주사율로 작동하며 Nvidia 3D Vision을 지원합니다.
How to make it run on 12V
I’d like to connect it to my Van electric system which runs on 12V, without having to use an inverter (since it kills the battery life). Any suggestion or recomendation will be most appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
There is no other way than 110VAC to power this monitor. You could look for a monitor that has an external power adapter and coax power input.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I know that, yes, an inverter would take more or less an extra 30 watts when running, but unless you are running the engine, it doesn’t matter which way you power the monitor, the monitor’s watts/consumption will be the same. Car/Van batteries are not designed to be drained in this fashion, with the engine off. They will be ruined if they are deep cycled. Now, if you have deep cycle batteries or are running the engine, then an inverter is the way to go because battery life will not suffer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gon Arada 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 629
