주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto Z4는 Motorola의 Moto 컬렉션 제품이며 모델 번호는 XT1980-3 및 XT1980-4입니다. 5G 연결을 지원합니다.
Screen replacement tools ands part
Cracked screen I need parts
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 6개
InjuredGadgets.com
의 공유
So where is the guide to fix it?
의 공유
Could not find any guides there.
의 공유
@ruppertj It opens up just like the Z3, but the ribbon is on the right side. I would recommend disconnecting the battery first.
의 공유
Well this was a day late and a dollar short, It would have been helpful if the cause of the screen separating from the body was caused by the battery expanding from gas build up. This did not effect the battery performance but it surly is the cause of the screen separation. This should be noted as the main cause of screen separation and the screen cannot be replaced until the battery is replaced. I wasted two screen replacement kits Z2-Force and Z4 because of the batteries had expanded. This was the cause in my Z2 and Z4 screens to separate.
의 공유
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
Hi,
There are suppliers online.
Just search for Moto Z4 LCD part with tools to get results.
Here are just two suppliers found on a quick search
example 1
example 2
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
InjuredGadgets has the screen as well but I would get the Genuine and not the other cheaper one from them.
의 공유
댓글 달기
I think iFixit sells a wide range of tools and replacement parts, if that’s what you mean.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
If you read carefully no that not what I mean ...moto z4 is the title
Screen Replacements tools and parts ..that the subject...and finally
Cracked screen ,,I need part that's the message..
의 공유
댓글 달기
Both of those examples are LCD screens which are for the cheaper Moto z4 play. The original Moto z4 has an OLED screen. Make sure to look out for this because as far as I've researched, they are not compatible with each other.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Alexandre Domon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 3,701
