주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Device is slowly loading.
Good day. My device is slow. If I open normally application I must wait few seconds, this is not bad but sometimes waiting time is minimal 10 second. But if I try open system app, like Phone or Gboard, I must wait minimal 10 second. After rebooting phone, I must wait minimal minute before he fully loaded. Can I repair by resolder memory chip?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @tony_iv_cz ,
Try clearing the phone’s cache partition and check if this improves performance.
Use the Volume Up/Down to scroll and the Power to enter
DO NOT select wipe data/factory reset as this will erase all your data and downloaded apps and restore the phone to its’ factory default condition (or last system updated condition)
Update (01/15/2020)
Hi @tony_iv_cz ,
OK.
Try starting the phone in safe mode and see if it loads more quickly.
If it does then the problem is caused by a downloaded app. You need to uninstall each downloaded app, one by one and then test the phone in normal mode between each uninstall to check if it works OK.
If it does then the last downloaded app that was uninstalled was the culprit.
If it s still slow when in safe mode, try a hard reset.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its’ factory default condition.
Before you do this backup the phone first to a PC etc first using the phone’s backup feature.
When you have backed up the phone perform the hard reset.
When the reset has been completed test if the phone loads normally.
If it doesn’t then you have a hardware problem.
If it does then restore the phone from the backup that you made earlier using the phone’s restore feature.
Once the phone has been restored to what it was, check if it still works OK.
If it does then the reset has resolved the problem.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I am try this, but without result.
의 공유
Ok. In safe mode work fine. I try remove all downloaded apps and files.
의 공유
댓글 달기
답변을 추가하세요
Tony_IV_CZ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 1,007
