주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 노트북은 2016년에 출시되었습니다. 모델 번호: i5368-10024GRY ASIN: B01F3R99HY. 이 기기를 올바르게 수리하려면 스크루드라이버, iFixit 여는 도구 및 스퍼저가 필요합니다.
How do I replace the keyboard?
Is there a guide to replacing the keyboard on an Inspiron 13 5xxx series laptop?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Hi @gordol ,
Here’s a link to the Inspiron 13 5000 Series 2-in-1 Service Manual
The keyboard is part of the palmrest assembly which means that you’ll nearly have to completely dis-assemble the laptop to get to it.
Scroll to p.81 to view the necessary pre-requisite steps and then the procedure to remove / replace the palmrest assembly and keyboard.
Don’t know with your model but on other laptops where the keyboard is part of the assembly, if you wish to replace the keyboard only, you’ll find that the keyboard is permanently attached and has to be literally snipped off the palmrest and a new keyboard glued back into place.
Here’s a link that may be of some help in that regard.
Keyboard replacement possible? Dell Inspiron 3147
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thank you. That is what I was looking for, but could not find.
The replacement keyboard I got off of Newegg claims to be for this and other 13-5xxx models, and appears to screw in. We'll see. Right now, I'm stuck on stripped screw heads on two of the screws that hold the motherboard on. Dell torqued them down too tight. I have a set of precision extractors on the way from iFixIt.
의 공유
댓글 달기
Follow these steps:
  1. Unscrew the screws from the backside of your laptop.
  2. Remove the backside of the laptop.
  3. Pop-out the keyboard using a spatula (or a similar instrument) from the corners.
  4. Replace the keyboard.
  5. Follow the above steps backward from step 3.
Hope this helps!
Regards.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Hi @judysmith712 ,
You're braver than me working inside a laptop without disconnecting the battery first ;-)
의 공유
Oh I forgot to mention that. Sorry. My bad.
의 공유
Um, there's a motherboard, battery and hard drive between the back case and keyboard.
의 공유
댓글 달기
답변을 추가하세요
Jeffrey Kaplan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 2,583
