주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
Repair and disassembly information for Logitech's ergonomic MX Vertical wireless mouse. Released in 2018 and identified by model number M-R0074.
5 질문 전체 보기
MX Vertical Optical Repair
Hi there, my MX Vertical isn’t moving the cursor anymore.. However, the buttons still work (e.g., left/right click, wheel, fwd/back, etc.). Does anyone know of a way to repair this?
Is the optical sensor easy to replace? Could this perhaps just come loose?
Any experience with this issue would be greatly appreciated as I haven’t seen anything pertaining to this particular mouse.
TIA
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Wow, thank god for the internet. This was super easy to fix once I found my super tiny electronics screwdriver. I dropped my mouse super hard and thought it was done for. So glad that this $70 mouse was salvaged from the landfill by some quick googling and helpful photos. Thank you so much!
댓글 달기
답변 8개
선택된 해법
So I figured it out. Thanks to that video provided by @justicegoat I was reassured that this device could be opened safely without breaking it, i.e., no glue.
I opened it up and noticed that the sensor was just loose and was no longer pointing to where it should be. Unfortunately the anti-stick strips couldn't be salvaged.
It was easy to clip it back in place. I had dropped this mouse from my desk enough that it must've dislodged from its clipped home. Oops.
Great mouse, though.
See images.
이 답변이 도움이 되었나요?
점수 15
댓글 8개:
Thank you, thank you. Even I, a 64 year old grandma with limited tech experience, was able to fix my mouse. Thank you!
you save my mouse, thank you !
100% - -Just saved me getting a new one - was sensor that had moved after dropping it -- Thank you sir :)
Thanks a lot, Sir! You're a saver.
This worked for me too. Thanks for your help!
댓글 3개 더보기
댓글 달기
Found this video, it’s in Vietnamese but it helped me open the mouse and fix that cursor issue.
turns out the lens connector was loose
Good luck!
https://www.youtube.com/watch?v=09ffN9M6...
이 답변이 도움이 되었나요?
점수 6
댓글 달기
I followed @l3fl3r instructions. Thanks!
Also, by being careful, I managed to remove the anti-stick strips/skate/feet and put them back after.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
you can find replacement scates on aliexpress, search for ..2 Set Mouse Feet Glide Sticker Curve Edge Skates For-Logitech MX Vertical/MX Anywhere 3 Mouse M04 21 Dropshipping
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I don’t think you can replace the optical sensor since most mouses have it soldered on the mainboard.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
No, you're correct. When I contacted Logitech, to order the anti-stick pads I ruined, they only offered to replaced my mouse. So spare parts are not going to be available. But In my case, the issue was the sensor and since it was an easy fix, I can still use it. But without the pads, it's not great for anything requiring any high dpi. It'll be a donor mouse should I run into any issues with my replacement.
댓글 달기
Thank you for the useful information.
Also, I was able to save the anti-stick strips by using a heat-gun to revove them and then to re-attatch them. I heated up the strips so that the glue turned softer and allowed me to remove the strips easily. When I was ready to re-assemble, I heated up the strips again so that the glue became sticky again and then just put them back on the mouse.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There is no need to replace or remove the anti-stick strips! You can simply locate the screws by sliding your nails along the strip and feeling for the holes. Once you find a hole, simply use the screwdriver to pierce through. This way, the strip remains intact ;)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thanks for the solution. I could repair my MX vertical. I can confirm that by being careful is it possible to reuse the pads (I started to peel them off with a blade and then remove it very gently).
By reassembling the optical sensor, I've put a small drop of glue on the support, I hope that it will be less prone to come detached again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Lefler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 62
지난 30일: 240
전체 시간: 9,964
