주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo IdeaPad 110-14IBR은 500 GB 하드 드라이브와 2 MB 캐시 메모리를 탑재한 15.6인치 노트북입니다. Lenovo에서 생산하는 IdeaPad는 2008년 1월에 처음 출시된 소비자 중심의 노트북 제품군입니다.
How do I get into my disk player
how to open disk player
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
If you have Win 10 installed try the following.
Click on the Windows Start button (left side of Taskbar) and then type My Computer in the Search box, click on the This PC app option that appears. Then right click on the DVD drive icon that appears in the Devices and Drives section and click on Eject option and see the the DVD tray comes out.
If the drive tray does not come out, on some DVD drives there is a small paperclip sized hole in the front of the drive. If you press an opened paperclip gently into the hole far enough you feel it click and the tray will manually pop out far enough for you to grab it and gently pull it out to its’ maximum travel.
If it does open this way there may be a bent DVD disc stuck inside preventing it from opening electrically or the DVD is faulty.
If there was a disc inside, after removing the disc, try closing the DVD drive by gently pushing the tray until it closes itself and then try opening it again using the Eject option just to prove that it is working OK.
If there is no DVD stuck inside then the DVD drive will have to be removed from the computer and inspected as to the cause of the problem.
Here’s a link to the hardware maintenance manual for your laptop taken from this webpage.
Scroll to p.32 to view the procedure to remove the ODD (optical disc drive) from the laptop so that it can be inspected or replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
percy davies 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 1,097
