주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 3월에 소개된 The Mac Pro (Early 2009)는 Intel Nehalem 아키텍처를 Apple의 전문가용 데스크탑 라인에 도입하였으며 미묘하게 재설계된 내부는 2010 및 2012 CPU 업데이트를 통해 소개되었습니다.
Vega 56 Power connectors
Hi, i want to use a Vega 56 in my mac pro 5.1 it has two 8 pin connectors. I have a cable from 2 mini 6 pin to one 8 pin. Is there any cable from 2 sata to 8 pin to connect the second 8 pin on the graphics card? thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
To get 8 pin power you will need to perform a mod called the Pixlas mod. It’s not overly complicated and if you’re interested here’s a tutorial.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
actually, the Mac Pro can comfortably use Vega 56's without a Pixlas mod.
two mini 6 pins to 8 pin PCIe cables are enough as the two mini 6 pins actually carry around 120 watts each, and the PCIe slot makes 75. this gives you just enough power to run a vega 56. but i would not recommend using anything more powerful than a 56
(normally mini 6 pins only make 75 watts according to the pcie standard, but apple seemed to break that for some reason, maybe anticipating more powerful gpus in the future)
댓글 달기
답변을 추가하세요
florian-lang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 928
