주요 콘텐츠로 건너뛰기
구글 픽셀은 2016년 10월 20일에 출시된 구글의 첫 번째 플래그십 스마트폰입니다. 5인치 AMOLED 디스플레이 장치에는 32GB 및 128GB 스토리지 옵션이 제공되며 베리 실버, 콰이트 블랙, 리얼 블루의 세 가지 색상으로 제공됩니다.
20 질문 전체 보기
How to replace power button
I saw that ifixit sells original Google Pixel (not the XL) power buttons, but there’s no guide on it. On top of that, I couldn’t find one anywhere on YouTube. If possible, could someone make a guide on how to replace the power button? Or at least show me how to? As old as my phone is, I still want to use it a little bit longer before I commit to buying a new phone. Currently, my screen and battery are broken, and I’m seeing to replacing them soon as not everything I want is backed up. I want to be able to fix every issue my phone’s been giving me since late 2018, but I don’t want to seem like I’m telling you how to do your job or that I’m entitled anything. I just really enjoy seeing the community help each other, and I find it hard to believe that I’m the first person to say something about the faulty power button since the phone’s launch in late 2016. On a sidenote, most teardowns of the original Pixel (not the XL; I only found two) never touched the power button, so I’m lost on that end as well. I’d highly appreciate it if somebody could make a guide. This is on a much lower priority than the power button, but if somebody could inform me as to where the bluetooth is located within the phone would be helpful as well. I know I’m asking a lot, but the bluetooth thing is more of a want than a need, unlike the power button. Thank you to whoever decides to reply, as I will be at the mercy of your advice.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @s4_rose ,
Did you notice that at Step.20 in the ifixit Google Pixel Motherboard Replacement guide, it mentions disconnecting the power and volume buttons ribbon cable from the systemboard?
Perhaps the guide is sufficient to help you to replace the Power / Volume buttons.
If you do decide to use the guide take pictures as you do the repair and then you can create a Power / Volume button repair guide for others to use in the future. ;-)
Here’s how to do this
Dare To Repair: How To Create a Guide
Most of the guides found on ifixit are created by contributors, just like you and not by ifixit
Google Pixel Motherboard 이미지
안내서
난이도:
어려움
1 - 2 hours
iFixit 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I wouldn't have thought to look at a different repair guide, but that does makes sense. Any repair that requires you to disconnect the power button would also include this. But no, I didn't notice that it was in that guide because I haven't replaced my motherboard before.
댓글 달기
답변을 추가하세요
Philip Wong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 128
전체 시간: 2,082
