주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
독립형 냉동고에 대한 수리 정보입니다.
Blomberg freezer Showing Error code E9
My blomberg FNT9673P Showing a Red triangle sign that there is somthing wrong with it, and Showing an error code E9 .
I searched every where to know the error code meaning and downloaded the manual. didn’t find anything .
Does anyone know the Code is for what ?
and is there any possible way to reset it ?
thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Wherevto buy parts for the blomberg appliances
의
댓글 달기
답변 1개
선택된 해법
# E9 may be a defective temperature control. You'll need to replace the thermostat
  1. Blomberg refrigerator error codes e9. If there is the “E9” error code on the display, the ice maker sensor is not working properly. Most likely, it has shorted or the wiring has been damaged.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
I have same issue and found defrost heating element faulty ( tripping earth leakage circuit breaker). As a matter of fact the fault code E9 showed up after removing heating element for diagnostic purposes. I have purchased replacement part but still need to see if fault code clears itself up on its own.
의
댓글 달기
답변을 추가하세요
Michael Samer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 74
전체 시간: 11,191
