Screen Replacement ( To Glue Screen And Frame)
Can I use any Adhesive Gum like Fevicol to Glue my Screen and Frame Or should I use any particular Glue like B-7000 ?
좋은 질문입니까?
좋은 질문입니까?
@pro_gamer this “The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.” from Huawei Honor 8 LCD 및 디지타이저 교체here. Any other glue will be a PITA to remove if you need to replace it again.
이 답변이 도움이 되었나요?
how do you replace the new screen, with band or glue
Only use adhesib t8000 glue or gum.My
experience about 10 years its good.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 910
