주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy x360 15m-bq021dx는 Hewlett Packard에서 설계한 노트북입니다.
Windows Vista Boot Error
I am running virtual box and I installed Windows Vista Ultimate 64 bit. But after installation, it restarted and it kept saying missing file at location windows/system32/drivers/wdf01000.sys someone pls help cause I want to use vista
Edit: I tried everything. I did system repair, diagnose and everything
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
“It seems that this problem is because the wdf01000.sys file itself has somehow been corrupted.
All you should need to do is obtain a copy of the file from a working install of Vista. It is located
in C:\Windows\System32\Drivers. Just copy it to a CD or USB drive. Boot your computer from
a Windows Vista repair disc or from your Windows Vista Installation DVD. On the second screen
select Repair. Skip the automatic startup repair and click the option to open a command prompt.
Now change your directory to C:\Windows\System32\Drivers and rename your wdf01000.sys to
something like wdf01000.old. Now copy the wdf01000.sys file from your CD or USB drive. Exit
the command prompt and reboot the system. You should now be up and running.
NOTE: Make sure the version of Vista you get your file from is the same version. In other
words don't copy the file from a 64bit version to a 32bit version etc.”
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It is helpful, but I don't have any working computers with a CD or DVD drive. Also virtual box doesn't accept USB sticks.
댓글 달기
답변을 추가하세요
Kyle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 374
