주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA Voyager Pro 태블릿은 경이로움과 엔터테인먼트의 세계로 입문하기에 완벽한 기기입니다. Android 5.0(Lollipop)을 탑재한 Voyager Pro는 즐거움과 재미를 선사합니다.
Not charging or powering up
I have a RCA tablet and it's trueing on or charging how can I repair it I've already tried turning it off and on again
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
Try connecting the tablet to a known working USB port in a computer and check if it starts to charge.
If it does it will be slow because the laptop only supplies a limited amount of current.
Let it fully charge and then try to turn it on.
If it works perhaps your charger/charger cord may be faulty.
If it charges or even if it doesn’t, use a straightened paperclip to try and reset the tablet using the recessed reset button in the tablet. (See image below for location of the reset button)
Gently push the paperclip into the reset hole until you feel the button operate. Hold the button operated for about 10 seconds and then remove the paperclip.
Connect and switch on the charger to the tablet and try to turn on the tablet
이미지
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sandra Chapman Richardson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 300
