주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
20 질문 전체 보기
Need advice on Tcon board repair
I am in process of repairing a tcon board The number is . ( T370HW02 V402. Cntrol BD 37T04-C02 ) I have a problem with the IC U201 ( AS15-F ) . There is 4 bits on the board missing were pin no`s 1, 16, 17, and 48 soder to is missing as in picture . Does anyone know were these lead to on the board so i can repair it properly , I am enclosing pictures so yous can see what i mean also a diagrahm to see ,Thankyou in advance as i don`t understand what the x,x,No ,Mo. means.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
@moggy01 not sure how you posted your images but can you repost those in a higher format and larger size. They are relatively small and when enlarged become unfocused. From what i can see, and I am old so my sight isn't great to begin with, it should be possible soldering jumpers across the destroyed solder pads.
Thankyou oldturkey03 hope these other pics are ok as i just need to know were to join wire to from the pins i mentioned , 1,16,17,48. Thnx again. See my answer for pics
댓글 달기
답변 1개
가장 유용한 답변
이미지 내용 보기:
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
moggy01 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 906
