주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sonos Playbase는 블랙과 화이트 색상으로 제공되는 세련되고 낮은 프로필의 가정용 오디오 기기입니다. 2017년 4월에 출시되었습니다. 모델 번호: PBASEUS1
Playbase not powering on
Is there a guide to replacing the fuse? My playbase will not power on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi, did you finally fix it? My play base is also not powering on and Sonos does not repair it because it’s 4 years old….
의
댓글 달기
답변 1개
Hi,
There isn’t a guide on ifixit to replacing the fuse but there are guides on how to replace other components in the device.
These will help you to open the device and locate the fuse, if that is the problem. It may be something else entirely
Sonos Playbase
Usually fuses are located near to where the incoming power supply is connected to on a board.
Be aware that fuses come in all shapes, colours and sizes so it may not look like what you think a fuse should look like.
Just look for a component with a board component designation beginning with F. F= fuse.
If you can’t locate the fuse take some close up images of the power board and post them back here.
Here’s how to do this.
기존 질문에 이미지 추가하기
It will also be handy if you have a DMM (digital multimeter) and a soldering iron and you know how to use them both as you may have to prove that the fuse is faulty or not for a start.
If the fuse has blown then there’s always a reason why a fuse blows which may have to be investigated and if it is OK then you will have to do further testing to find out what the problem is.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Calvin Ho 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 1,032
