주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Game Boy Advance의 업그레이드 버전인 Advance SP는 2004년 3월 23일 북미에서 정사각형 구조와 클램셸 디자인으로 출시되었습니다.
Unable to hold a charge
My GBA SP is unable to hold a charge, i can stick the charger in and the charge light wont light up. I think its not the battery, but a short in the charging input. anyone know some fixes?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Check batteries and contacts first
의
what makes you think that it is not the battery? Follow pollytintop's advise and change the battery first.
의
What is your model number on this? You will find it on the bottom of the case. The model number is either going to end in 001 (the original one) or 101 (New Brighter Screen). When you plug the charger in does the charging lite briefly flicker (turn on then off quickly) as you plug it in or does it remain off.
의
mine ends with 001 and the charging light comes on when i plug it in then goes off instantly i just installed a new battery and got a new charger also and still the same thing.
의
댓글 달기
답변 1개
선택된 해법
Just for kicks and giggles, has any of you two tried to clean the battery contacts. make sure that the contacts are actually getting to the battery and check the fuse as well. I would do that before trying to send it off.
이미지
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
How do I "check the fuse" ?
의
댓글 달기
답변을 추가하세요
Clayton Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 4,764
