주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1297 유니바디: 2009년 상반기, 2009년 중반기, 2010년 중반기, 2011년 상반기 & 2011년 하반기
Metallic taste from surface of laptop
There is a curious metallic taste coming from the track pad and surface area of my mac book pro.
Has anybody encountered this situation ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
happen with any other equipment? ever thought it could be your electrolytes?
의
what was wrong with the answer you received yesterday to this same question? Mayer knows his bickies and I think he has a very valid answer.
의
Don't lick your laptop
의
I m having a similar problem. Even when using imacs I feel a pinching feeling like pepper in my nose, lips and Metallica taste
의
댓글 달기
답변 4개
선택된 해법
Have your dentist replace your silver amalgam fillings with a composite material. Your metalic taste is most likely being caused by the slight electrical current discharging in your mouth via your fillings. Read up on it here: http://www.drpgilbert.com/metallic-taste...
이 답변이 도움이 되었나요?
점수 20
댓글 5개:
Didn't know this was possible. +
의
I was thinking similar lines re small current/electrolyte problem but more localised, it's a good read.
의
+ Hah! I had no idea this was possible. Crazy stuff.
의
Did you find the answer to your problem?
의
Early in my life I had a dental laboratory and did crown and bridge work, went to lab school for two years.
의
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
I don't think it's normal to experience tasting flavors from simply touching an object.
That said, if you are touching an aluminum case and you lick your fingers afterwards, it's possible that you could be licking up some aluminum dust.
Either way, I wouldn't recommend licking your fingers or your laptop.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
My dog does that for me ;-}
의
댓글 달기
I would try adding a colloidal minerals supplement in the liquid form to your diet to see if this resolves any mineral deficiencies you may have. Many of the minerals are metals. In chemistry the Theory of Equallibrium tells us that all touching matter exchanges atoms. I would also try washing your hands prior to touching the track pad. Colloidal/Ionized minerals are in the form of salts. Your sweat has salt in it.
Look to see if touching other items brings this sensation. That may help you narrow down the cause of it.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
that's what I was thinking.. you put it much better than i could.
의
I think if you had elaborated on your thoughts Poly that your words would have been more eloquent than mine. However no one seems to view our thoughts as a viable solution to the problem at hand.
의
ha ha..at hand! get it? ah well no one else will either. ;-P
의
댓글 달기
sometimes, when i move myfingers over the metal part of my laptop, both the unibody and the one before, i feel some ‘stick-slip’. it is gone when i unplug the power. clearly, some voltage comes through.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Michael 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 17
전체 시간: 2,578
