주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
What do I need to do and get to fix touch ic
I have a iphone se that I posted about earlier, ill put the link in the description. I watched a video of a person repairing a 5S and he used a heat gun and some brownish liquid substance, but there is no video for repairing the SE touch ic. I do have a soldering iron that can microsolder and I am experienced in soldering but im new to iphone motherboard repair and microsoldering. I am on a tight budget so can I just order the touch ic and fix it or do I need to get a heat gun, the substance?
also Is there a video for repairing the touch ic on my iphone SE?
iPhone se touch intermittently unresponsive
Update (03/07/2020)
I already have a lot of supplies for microsoldering except a hot air reflow. soldering paste, and wickets, do ineed those too?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Brayden, if you want my honest opinion…this is not something you should follow through on if your goal is to actually repair this phone on a budget. If your goal is to learn, then go for it.
Your question shows that you really do not have the proper tools, consumables and experience in micro-soldering and that you will probably muck things up more than anything else. I don’t say this to be harsh, just to save you time and money. If you really want this phone to work and quickly, let someone else do it.
That said, I don’t think you should be investing money on a water damaged device. I don’t know any techs that actually fix water damaged devices, they can have all kinds of latent issues and are a warranty nightmare.
Now, to be fair, if you want to learn then you will need a hot air gun, paste flux, good tweezers…and tons of practice on dead boards before ever attempting to repair a valuable device on your first try.
Feel free to ask any follow-up questions!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
thanks, I do solder but i havent encountered microsoldering. I just have a soldering iron that will do it. I do have a LOT of dead boards so ill practice on those, thanks
댓글 달기
귀하의 답변을 추가하세요
Brayden S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 173
