주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for the HP Chromebook 11 G6 EE. Released in 2018.
5 질문 전체 보기
Where is the write protection screw on this model?
Can’t find the screw been messing around for an hour.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Protection screws are generally near the main processor on the logic board. Note that most of these laptops will have a metal cover that acts like a heatsink. Under the metal cover one screw hole may have a sticker blocking the screw or cover from shorting the contacts on the logic board to disable write protection of the system software.
Another one is that it may be using an opposite way to disable where you leave the screw out as well or put tape to block it from shorting the board.
Should be a mark on the board where it looks like it may be bridging the contacts as shown in this picture:
https://memcpy.io/images/2017-02-27_wp_s...
If you see any similar to that you either need to unshort the contact or short it to disble write protection. Either by covering it up or removing the cover.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Truitt Detra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 77
전체 시간: 8,519
