주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TKD Life on Record A33은 방수 블루투스 스피커 입니다. 2012년에 출시되었으며 현재 단종 되었습니다.
Sound cutting in and out
My A33 was dropped..a few times. After the 3rd accident, sound cuts in/out sporadically with the speaker stationary. I might need to go deep inside to check out connections (power on indicator never waivers and Bluetooth connectivity appears solid). I’ve tried shaking it while playing some tunes and that doesn’t make a difference. Ideas on what the problem may be? Is it possible to fully disassemble to check the circuit boards?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @rwenner007 ,
Does this occur when using the aux in connection as well as the BT connection?
If only on BT it might be the aux in jack.
Not sure whether the BT audio comes through the jack contacts and is disconnected when a cord is inserted or whether the jack uses a contact to signal the audio controller to switch inputs when a cord is inserted but still maybe worth a check anyway
Here’s the ifixit TDK Life on Record A33 guide which may help to gain access to the internal components
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rick Wennerstrom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 432
