주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv6 모델 노트북 컴퓨터에 대한 수리 및 문제해결 정보를 제공합니다.
How do I replace the fan
What are the procedures for replacing the fan?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @brandtk ,
Here’s the maintenance and service manual for the laptop.
Go to p.91 to view the necessary pre-requiste steps and then the procedure to remove/replace the fan.
On p.90 you will find the part numbers for all the fans used in this laptop model series. If you search online using the appropriate to your particular model fan part number only, you’ll get results for suppliers of the part.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
simple if your fan is not working its easy and its very cheap to buy oem parts online..it only cost a dollar..
remove teh battery first then you have to remove all the screws of your lap top ..then you might want to take a picture of the cable wires or ribbons before you took it apart that way you can remember how to put it back..
then remove the dvd drive the ssd the ram and then you need to pry open the keyboard area..unscrew all of the screws un plug the ribbon connecting the built in mouse and keyboard,then remove the lcd ribbon remove all the ribbon gently ..
then you can remove the keyboard housing by prying it gently using a flat screw..when the board is expose now
remove the power ribbon the fan ribbon located on the rigthcorner their is a hidden screw beside the fan remove that as well,then unscrew the 4 gold screws that attach the mother board to the housing…you can not replace the old fan with a new fan…you might as well clean the fan holes or check if their is dirt or dust blocking the airholes..
then screw it back just the way before..return all the cables to their locations turn on your computer …there you go you fix it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brandt Kehoe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 18
전체 시간: 663
