주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude E5530은 Windows 7 Pro 64비트 운영 체제를 실행하며 내구성이 뛰어난 배터리를 탑재한 휴대용 컴퓨터입니다. 무게가 무려 5파운드(약 2.27kg)에 달하는 이 노트북은 듀얼 코어 i5 CPU와 4GB RAM을 갖추고 있으며, 매우 편안한 키보드와 트랙 패드가 장착되어 있습니다.
Computer running too slow
I have a latitude e5530 running Windows 7 Pro with Intel Core i5, and it runs very slow. I start up the task manager, it only uses about 8% of the CPU on average. There is also something wrong with the speakers, there is usually either no noise or it is very faint. I put the volume to 100% and nothing changed. Is there a way to fix these problems?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 5개
선택된 해법
Upgrade hard drive to SSD. This will improve performance.
Upgrading to Windows 10 would also spped it up. It is still a free update with legit W7, as far as I know.
I would especially think this with Task Manager showing only 8%. The old hard could possibly be ready to die.
What temperatures are CPU, etc.?
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
How would I be able to see the details you ask for? I can't find the CPU temp in the Task Manager
의 공유
Do you know how to get to hardware monitor? it is a free software that can check temp, and other things etc.
의 공유
What's their site?
의 공유
@sjhralbert
Sorry have been doing TAXES for last few days.
https://www.cpuid.com/softwares/hwmonito...
의 공유
의 공유
댓글 달기
Try cleaning the speaker. It helps with the noise. Take the speaker out of the computer, and brush off anything.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Well, since this is a 11-year-old model, you have to take off the motherboard and all to see the speaker itself.
의 공유
And what about the slowness problem?
의 공유
No, for the speaker. I forgot that it...
의 공유
댓글 달기
All Dells have a Service Tag (like a serial number) on them. For that model, it will be on a sticker on the bottom, possibly under the battery. If you can find it, write it down.
Then, go to Dell’s, website here: https://www.dell.com/support/home/en-us/...
If found the Service Tag I mentioned, type it into the Dell website. This will give you all the system’s details, including how it was configured when it was originally built.
Regardless, all of the Dell software mentioned above can also be found on the same website, two tabs over. Or here: https://www.dell.com/support/home/en-us/...
Finally, this is everything you’ll likely need to dial that Dell back in (also on Dell’s website) https://www.dell.com/support/article/en-...
HTH
이 답변이 도움이 되었나요?
점수 0
댓글 달기
To fix the fan problem try cleaning the fan and shooting some air at the whole thing and for the speakers try looking where the connect cause they could be loose
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The whole thing meaning the whole computer
의 공유
댓글 달기
I fixed the speaker problem, apparently there was something wrong with my headphones. I used another set of headphones and the audio sounded as crisp as it used to.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Albert Einstein 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 32
전체 시간: 1,351
