주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
구글의 3세대 픽셀 브랜드 스마트폰이자 최초의 '홈 화면' 스마트폰입니다. 6.3인치 QHD+ OLED 디스플레이와 64GB 또는 128GB 저장 용량을 제공합니다. 거의 흰색, 저스트 블랙 또는 핑크색으로 제공됩니다.
Black Screen after Display Replacement
Hello, This google Pixel 3XL I have had a damaged lcd but the screen was still visible it was just cracked. I went to do the screen replacement and everything came off fine and there is no visible damage, but after replacing the screen the display is black but the phone is powering on, so i assumed that the new display I had received was defective, but i put on a second screen today and it is having the same issue. Any help would be greatly appreciated trying to get this running asap. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
It appears that the display would not come on completely until the back cover of the phone was put into place and the capacitive pins on the touch ID sensor were making contact, very strange issue, but once all together the problem was resolved, and the display came back on phone appears to be working fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Did you disconnect the battery before you removed the screen? .you could have damaged the back light circuit. Look and see if you can see anything is a darker room and shine a light on the screen. And see if you can see anything.
Update (06/11/2020)
It sounds like you might have blown a filter on the back light circuit. You should pull the board out and check the circuit. Or if this is out of you skills take it to a repair shop. You will most likely need do microsolder work.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
The battery was disconnected before the screen was removed. I have shined a light on the screen and cant seem to see anything. It appears that there is no backlight, the screen seems to not be powering on at all but the phone is vibrating and notifications sounds are coming through.
의
Update: It looks like once i had the back panel re connected with the touch id touching the capacitive pins then it brought the display on, not really sure as to why this would work but it did. Thanks for your comments, and I am a repair shop and it doesn't appear any microsolder work is needed.
의
Ok. I didn't know what your skill level was. Glad you figured it out.
의
Yeah it's not problem haha thanks for all the suggestions it helped me work through the problem.
의
댓글 달기
답변을 추가하세요
Matthew Clark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 3,266
