주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Series 5 3G Chromebook. 이 노트북은 웹 브라우징에 이상적인 12.1인치 Super Bright 고해상도 비반사 디스플레이를 갖추고 있습니다.
Galaxy Tab 3 10.1 shuts off...
When my power level gets below a certain level, if I plug it in to charge it, it just drops to 0% and shuts down.
I have limited experience with device batteries in these kinds of electronics, particularly Li-Ion. With tools if they over heat they;ll shut down and come back up in a few minutes. This is a genuine drain to 0%. Is it the battery, or something else? Any one?
And why aren’t tablets listed as an available device any where in the device list?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Is it imprinting, like NiCads do?
It will re-charge with out a problem.
의
댓글 달기
답변 1개
If it completely shuts down while plugged in, your charger might be bad. On Powe settings, the power plan might be shutting off the screen but the computer actually remains on until keyboard or mouse activity is detected. If this isn't the case, test the charger output. Your computer should indicate plugged in and charging . If not, the charger is bad and you need to get a new one.
If the charger is known to be good and it STILL doesn't charge your computer, kindly check out the post.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Norman Hendrikcson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 8
전체 시간: 239
