주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP는 2016년 10월에 인체공학적 디자인의 이 노트북(모델 번호 15-au123cl)을 출시했습니다. 이 제품은 Windows 10과 터치 스크린을 특징으로 합니다.
Boot device not found
Hi,
Please I need your help. I did a Windows upgrade from 8 to 8.1 and after the upgrade I wasn't seeing wifi connections so I tried to resolve this myself. With the suggestion I got from the virtual assistant, I did a BIOS configure and saved the default settings. Now I can't boot my PC. It keeps saying Boot Device Not Found. Please what do I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Start the laptop and then quickly press the Esc key followed by F10.
This should get you into the BIOS menus.
When there check if the BIOS has detected the HDD.
If the HDD is shown in BIOS I’m not sure with the BIOS in your laptop but once in there it should show which keys to operate to reset the BIOS to the default settings. Try doing that, save the changes and then restart the laptop and check if it boots OK
이 답변이 도움이 되었나요?
점수 1
댓글 9개:
Thank you for responding. I only saw press F9 to set default which I did. I still can't get pass the booting error
의 공유
@jesseyb
Try to perform a startup repair see Method 2
의 공유
Easier to press Esc. It's the magic key on HP products. That said, the key is usually F10 on the modern ones.
의 공유
Finally my PC has booted. I change the boot mode from UEFI to Legacy and it worked. So what do I do next? Should I still do the startup repair? Do I need to change back to UEFI or leave it as it is now?
의 공유
@jesseyb
If it boots OK and it all works OK and that you can restart it in the usual manner after you have shutdown in the usual way then it should be OK so change it back to uefi and see. If not OK when you do this you may have to do the startup repair in case something else has been corrupted
의 공유
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Jessey Anthony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 1,214
