주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Officejet Pro 8625는 팩스, 스캔, 복사 기능을 갖춘 HP 제조 무선 컬러 프린터입니다. 이 프린터는 8610/8620/8630 e-All-in-One 프린터 시리즈의 일부입니다.
Why does vertical line appear on document using ADF as source?
If I copy from the flatbed everything works fine. However if I copy or scan using the ADF, then a black vertical line appears down the center of the output document.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @delfino2107 ,
You need to clean the scanner glass window beneath the ADF. A speck of dirt or grime etc on the glass window will cause a vertical line to appear on the output document.
Be careful when cleaning. See the Cautions advisory notes in the image below. A slightly damp microfibre cloth seems to work quite well.
Here’s an image taken from p.34 of the user manual that shows the two separate scanner windows. The smaller one on the left is used for the ADF and the larger one is for flatbed scanning.
이미지
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
This problem was driving me nuts, and the answer is so simple to fix.
Wow! I can't believe it, this actually worked! This saved me from spending $1200 on a new printer. There was a small smudge on the scanner window of my printer. It was invisible to the naked eye, but caused a shadow to appear when I shined a flashlight onto the window. After thoroughly cleaning the scanner window and re-running the flashlight test, the vertical line no longer appeared. Thank you for the tip 🙏
댓글 달기
답변을 추가하세요
Eric Zarate 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 26
전체 시간: 1,607
