주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VLT 1000 데스크 팬은 지름 30 cm인 4개의 날개를 갖추고 있습니다. 스테인리스 스틸 소재로 제작되었으며 3단계 속도 조절이 가능합니다.
Fan speed slow initially
I have a tower fan which initially runs on low speed and after 20-30 min the speed becomes normal. What could be the reason and how to fix the issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Hi,
Does it run on low speed even if a higher speed setting is selected when starting?
Do the fan blades rotate easily and smoothly if you spin them by hand? (disconnect the power from the fan before you try this)
의 공유
Its at first two speed. At third (highest) speed, it functions well. Yes, the blades rotate easily and smoothly if I spin by hand.
의 공유
Can you run the fan at highest speed first for 2-3 minutes then switch to low speed? Tell me if that works or not :)
의 공유
Bahut slow slow chal raha hai
=== Update (08/29/23) ===
Bahut slow slow chal raha hai friend
의 공유
Fan slow problom
의 공유
댓글 달기
답변 3개
가장 유용한 답변
@ sachin gupta
What is the make and model number of the fan as you have selected a desktop fan as the device and not a "tower fan"?
If the fan is no longer under warranty, you may have to open the fan and access the control board where the speed buttons are connected to and check the components. Usually with speed controls for fans, the switches connect or disconnect capacitors into the fan's motor circuit to increase / decrease the amount of current flowing to the motor so that it runs faster or slower.
If you see any problems or if you're not quite sure, post some images back here.
Here's how to do this 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 달기
sachin gupta besides the great suggestions given by @jayeff it is also possible that your fan motor is most likely starting to gum up. I suggest you tear it down right to the motor teh clean the rotor shaft bearing etc. with some contact cleaner/degreaser and some good puffs of compressed air. Dry everything off and apply some grease to the bearings etc.
It is also possible that the motor windings are starting to fail.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Please check the capester is fully fit or not and maybe the fault is in her capester because nothing that powers the fan
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sachin gupta 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 31
전체 시간: 2,437
