주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose SoundLink Color는 SoundLink Mini보다 저렴하고 휴대성이 뛰어난 대안으로 설계된 Bluetooth 스피커입니다.
How to replace the USB charging port?
I have a Bose SoundLink Color, the USB charging port and the 3.5 mm jack are encased in this black piece of plastic, which does not seem extractable although it has two plastic pins visible from the other side.
How do you suggest to proceed?
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I am having this exact same issue right now. Guess my plan is to desolder the combined usb and aux component, then see if I can open it up, and eventually replace the USB part. Maybe solder new wires on the other side of the right pins and drill a hole in the side for a brand new duplicate USB port.
의
댓글 달기
답변 2개
가장 유용한 답변
@hyklamin that is correct. The replacement comes like that. Here is the bad part, those are really hard to find and you may need to find a broken Soundlink to harvest that connector from there. Or, if you know somebody who can do 3D printing, make your own plastic casing with some options to slide a replacement USB port etc., into it. Then get some connectors from places like Mouser or Digikey and rig it up. PITA but doable. this is going to be more a re-engineering than a straight replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I am actually asking how to reach the base of the component I want to desolder. I can only think of melting the plastic.
의
댓글 달기
hola . tengo el problema con el parlante , que no carga ni enciende,pude desconectar la bateria y tiene carga. entonces para mi la bateria no es el problema. estoy revisando componentes a ver que encuentro. adios.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yklamin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 71
전체 시간: 4,650
